Led Panel sync
marvinbr
Led Panel sync
Post by marvinbr »
Good afternoon people,
I'm having trouble and sync on the LED panel.
I have 3 send cards operating this led panel.
I have a problem between the screen junctions, it shows a trace of the image. How can I explain it better.
There is a delay. Imagine an image rising (example a ball) right at the junction of the panel. This ball is cut in the middle and it gives a difference of 3 or 5 pixels of delay not making the ball perfect, but as if two halves out of sync had been rising.
Has anyone had this problem?
Computer is a rayzen 5 - 32gb ram, GTX1660S and SSD.
Thanks.
Re: Led Panel sync
Use a GPU that has a sync option built in like a Quadro, or use a FX4, or find a way to send one large raster to all screens using a professional splitter with genlock and map different quadrants within your processor. other than that there's not much that can be done to fix this. The term is called screen tearing.
marvinbr
Re: Led Panel sync
Post by marvinbr »
Thanks Michael, I will check if I can get the equipment for testing.
