DMX Manual IP Address
guillaume2097
Post by guillaume2097 »
Dears,
I actually use Resolume 5 and a LED controller H803SA.
I connected this controller with an ethernet cable.
I try on Windows 10 to set an IP address but my Ethernet icon have a red cross.
It's the first time I try to use Resolume with LED hardware
but at this stage it's looks more an ethernet recognition problem
can you help me please?
Thank you
Re: DMX Manual IP Address
Sounds like your connected device isn't sending a ethernet handshake. What happens if you use a network switch in between? I'm assuming your ethernet cable is good?
Holm
Post by Holm »
I know such devices, the sockets look like network sockets, but their function is not.
These parts only understand DMX, nothing else.
^FTW :D
We have a couple of LED Source 4's that do the same thing. It's 3pin XLR to Ethernet cable. Sometimes people do the dumbest things lol. (Just make them a 5 pin or an ethernet Artnet port, but this analog over a digital medium is confusing for everyone and stupid.)
Nice catch!
guillaume2097
Wooow
So if I understand
In this LED controller they have visually an ethernet input but it's not artnet ?
So I have no solution to change this hardware ?
Arvol wrote: Mon Feb 15, 2021 19:39 (Just make them a 5 pin or an ethernet Artnet port, but this analog over a digital medium is confusing for everyone and stupid.)
Or you mean I can change this 3pin ethernet to a 5pin ethernet easily?
I will looking in google if I find something about this topic right now
Thanks a lots everyone!
No, from what Holm is saying is that your ethernet port is NOT ethernet so you can't connect it to other ethernet devices.
guillaume2097
Ok thanks you for all information
I will check other LED Controller
Artnet 5pin !
Holm
Post by Holm »
Another possibility would be to buy a DMX Ethernet Node. Then you could use your LED controller and open up greater application possibilities.
