The composition cannot be dragged into the video, cannot load a new video
The composition cannot be dragged into the video, cannot load a new video,I have been using my composition, and recently encountered a problem, whether it is version 6 or version 7, as long as I use my composition, I will encounter the problem of not being able to drag in a new video, dragging it directly disappears, and some have encountered the same problem ? How to solve
Re: The composition cannot be dragged into the video, cannot load a new video
Sounds like you try to load unsupported files.
We recommend to use DXV encoded video clips with uncompressed audio.
All videos are DXV3.0 encoding
Could you please send us the Resolume log file via the feedback tab in preferences?
