I am at wits end with recorded files size so small
davidgodgluck
Post by davidgodgluck »
First of i have been recording visuals monthly for DJ mixes that are then broadcast via twitch ect. This are video files with matching audio files. Smooth sailing for the last year, my final recorded video out of Resolume nearly matches up with the time of the audio file, maybe a few seconds off in the course of 1hr plus videos. This time around I end up with 20-25 min video for over an hour recording. Ive tried everything I think of changing ect. even test recorded for 1min, 5min, ect and end up with about a little more than a third of video. As I said before never an issue before. I am running an i9 with rtx 2070 64 gb ram most recent updates. Resolume rarely glitches when I throw everything I have into it. Please HELP!!
Re: I am at wits end with recorded files size so small
Looks like Resolume is dropping a lot of frames when recording.
If you enable show FPS in the Output menu, what are the numbers you see in the preview monitor when recording?
davidgodgluck
Dropping a lot!!! My fps stays at about 1/3 of my fps setting only changing slightly when I change my fps setting composition. Running using 5% cpu and 18% memory and I'm dropping two thirds of my frames!!!
davidgodgluck
Frames are this low recording or not.
davidgodgluck
pretty sure i found the culprit!!! while its unfortunate and hope there is a bug fix for this in the future but problem fixed when i turn off Spout texture shareing
Spout, and other outputs use a GPU resources, it's natural that you see FPS drop with it.
Though an RTX2070 should be pretty capable and you'd need to throw a lot at it to see FPS drop below 30.
Do you have all your displays connected to the RTX, and is your primary windows display set to a monitor connected to the RTX directly?
davidgodgluck
Yes my monitors are connected directly to rtx. Ndi works just fine no frames dropping when it is running just spout.
How about a new composition with only a single clip playing, does recording work with that fine?
Could you please send us the Resolume log file via the feedback tab in preferences?
davidgodgluck
Sent. I have started new compositions and tried everything thing i could think of. Only thing that stays the same is when i turn on spout boom 70% frame rate drop.
Ok, then it's the spout output ;)
Can you try updating your nvidia drivers to the latest studio release, and double check that Spout DX9 mode is disabled?
You can use SpoutSettings.exe, which is part of the Spout installer you can get at https://spout.zeal.co/
