Move layer without moving the clips
timvangucht
Post by timvangucht »
Hello,
I would like an option that the layer and clips are separate from each other.
Now when you move a layer up and down you also move the clips in that row up and down.
But when you use the clips on a selected layer the clip dont need to move with the layer.
So an option in preferences would be nice.
He2neg
Re: Move layer without moving the clips
Post by He2neg »
The clips are the layer and the layer is the clips..
So... maybe you want to add a new layer instead?
~Berlin~
Or do you mean changing the layer order, keeping clips at their location?
timvangucht
Zoltán wrote: Wed Mar 03, 2021 15:29 Or do you mean changing the layer order, keeping clips at their location?
Yes this is what I mean.
Ok, for a quick workaround, create a new empty deck, switch to it, move your layers, and switch back to your deck with the content. This should keep your clips from moving.
