Green Screen Chroma Key + Crop Issues
bonjee
Post by bonjee »
Hey all,
I'm trying to key out a green screen but can't figure out how to do it.
I have cropped my video feed to show what I want it to show, and logically all i need is for the background to show instead of the green screen. However, when I add a chroma key effect the only thing that shows is the green screen part, and not the rest of the screen:
I'm sure this is just some blend mode option I'm missing, but I can't seem to work it out. Any help is appreciated :)
Re: Green Screen Chroma Key + Crop Issues
This works for me. I applied the ChromaKey first, then Crop.
bonjee
Post by bonjee »
that works! no clue what it changes but thanks so much :D
Chroma key makes the original texture alpha black, so the alpha the crop creates will be black if you use chroma key after crop.
