Example project for Avenue?
JouniAlkio
Post by JouniAlkio »
I was under impression that Avenue is supposed to have some kind of example project that you can open. If so, where should I look for it? I have not been able to find it.
- Jouni
Re: Example project for Avenue?
Yeah, it should open right up when you first install and start Resolume.
Looks like the process for this is broken again.
Start Resolume as Administrator (right click - Run As admin) and
go to Composition menu - Open
You can find the Example composition in Program Files\Resolume Avenue\Default\ folder
JouniAlkio
Yep, it opens when I start Avenue "as admin". Thanks.
