Resolume keeps adding 2 layers to my composition. I delete them, Save. Close, open. Layers are back.
Even if I switch scenes, they are back. First I thought this might by a "protection" because some of the "slots" in a scene are not empty, but they all are empty. But they keep re-appearing.
Whats going on? Is this a bug? Using latest version.
Extra layers being added. Arena Bug?
Desktop: Ryzen 9, 32GB Ram, Nvidia 2070S
4 x 4k Screens. One 4k monitor extra for Resolume Interface.
Laptop: Intel 7700, 32GB, Nvidea 1060, 2xNVME
Re: Extra layers being added. Arena Bug?
Nope this is normal. Just keep them there
Normal Averol? Are you sure.... i only see this when in other decks the layers are needed.... i could have a simple comosition with 3 layers and arena didnt add anything...
~Berlin~
~Berlin~
Yup, this is normal.
I'm pretty certain that one of your decks has a Layer count of "x", That layer count of "x" is what drives the layer count for the rest of your decks.
Here is a video that demonstrates how this system works:
Try creating decks that have the specific layer count you are wanting to use. Let's use 6 as an example.
Make sure all of your decks have 6 layers filled with content. Go through each deck and remove any layers above layer 6 and hit save, then move to the next deck and do the same process. Once all of your decks have 6 layers and have been saved (saved once per deck as your modify them). This will ensure that only 6 layers appear on all decks when moving through the decks.
If you did this process and then more layers are being added, Something wasn't done right, or there might be a bug, but I have yet to see this bugg happen (as demonstrated in the video.)
If this method isn't working for you, would you mind uploading a video explaining/demonstrating what's going on? Thanks
Yes this is what i call "normal" as well....
If one layer is deleted on all decks then it should NOT reapear
~Berlin~
~Berlin~
Be sure to save after you delete it from a deck before moving to another deck thoughHe2neg wrote: Fri Mar 12, 2021 10:10 Yes this is what i call "normal" as well....
If one layer is deleted on all decks then it should NOT reapear![]()
