Flickering/blinking capture inputs
Filipsz
Post by Filipsz »
Hi, pls help.
Reccomended gc, enough ram, processors, power
Latest drivers, connected to internet and ndi.
Dhcp automaticaly.
Outputs 4k 1x ledscreen
Monitor fullhd
One layer background composition.
Two groups on it but bypassed - left and right window
Each 5 layer, each bypass solo in advanced output
Advanced output used as it sould be.
Using delink duo on input OR one aver media and one usb capture, several ndi captures via network
Same problem in both situations
Flickering of group windows, when using inputs, randomly, after 6 hours of usage. , or after 2 hours, or constantly, or just once in a second
Strangest thing, when flickering, one capture flickers in thw window of another group! Right window flikers in left! But if not flikers, everything on right place!
Dont understand at all, using RA many years and saw lot of things but not all of them, seem to be.
Any ideas?
Many thanks
Filipsz
Re: Flickering/blinking capture inputs
Post by Filipsz »
Well, ndi/internet/dante over same switch.
Basically not good, right?
That's a weird one we're working on. #14816 Still trying to track down what happens, but
it happens only with the combination of capture and more than 1 NDI input.
If you contact us with your serial number on mail@resolume.com we might be able to figure out an alternative for you.
Filipsz
Post by Filipsz »
Hi thanks for answer. What alternstive you mean?
Different software? Want to use ra..
Will send serial asap, my boss have it
Filipsz
Post by Filipsz »
Email sent, thanks
Filipsz
Post by Filipsz »
So downgrade from 7 to 6.1.3 should solve this
Yes, this doesn't seem to be an issue in v6.
Also if you disable DMA textures in the Resolume video preferences, then that prevents the flashing for some reason.
That should be a quick workaround for v7.
