Dual monitor for Resolume interface
LJ2F
Post by LJ2F »
Hi Everyone !
I would like to extend my Resolume interface on 2 screens
Is this kind of adapter can do the job with Resolume ? :
https://www.startech.com/fr-fr/audio-vi ... sp122dp2hd
And then, if I want to add a video projector, or a third screen directly to my graphics card, will that work too ?
I mean, I could plug my 2 screens with the adapter on a first displayPort with my resolume interface on both screens. And, I could use a second displayPort for a third screen as my Output, as a monitor control for exemple. And then, I don't know, I could plug a video projector on a third displayPort of my graphic card.
Do you think this can work?
Thanks for your help
best
Re: Dual monitor for Resolume interface
On windows you can scale programs over multiple displays, so this should be no problem.
You don't need any adapters if you have enough outputs on your GPU.
LJ2F
Post by LJ2F »
Hi Zoltán, thanks for your answer.
I can click on the Minimize button and stretch the window from my first to my second screen. Then, if I click on expand, the program window fill only my screen 1 (or 2).
There is no way to fill the both screens with expand button in Resolume ?
I thought that the adapter could be detected as only one screen. And so, if I expand my Resolume window, the program would fill my 2 screens. Here is my question, I don't know if it could be worked.
Maximizing only works on one display.
There are display adapters like the Matrox Dual head, which can appear as one big display to the computer, and split that up to two outputs. With that the maximize would work, but I'd rather keep my money, and just do the stretch ;)
LJ2F
Post by LJ2F »
Hi!
Okay thank you for your help
