4k mov files causes crash on pc
jeffhtg2
Post by jeffhtg2 »
Trying to take mkv files into dxv eventually...
tried using obs to turn them into mp4's
then i bought winx hd - i assumed turning them into movs would be the logical step
both alley and resolume crash when i try to load the clip
Re: 4k mov files causes crash on pc
Could you please use the crash reporter dialog that pops up after the crash to submit a crash report?
That way we get lot more detailed information about what went wrong exactly.
Don't forget to fill out your email address, so we know it came from you ;)
jeffhtg2
Post by jeffhtg2 »
Zoltán wrote: Thu Mar 25, 2021 10:51 Could you please use the crash reporter dialog that pops up after the crash to submit a crash report?
I sent in the crash file to support@resolume.com - that computer is not and will not be connected to the internet.
I spent most of yesterday trying different approaches to convert the files. Finally what worked (with some guidance from the facebook page) was to use handbrake to convert the files to MOV first and then adobe media encoder to turn them into DXV3's. This two step approach really takes time and a lot of space for larger 4k files tho.
I don't understand what breaks the mp4 / mov's that i converted. I stripped audio, there didn't seem to be any other content that would break it. Anywho that is the workaround for now.. would be nice if Resolumes converter worked better for this kind of stuff as that is an increasingly popular file format.
Well, without the crash log, it's really hard to say what goes wrong. There should be an option in the crash reporter to bundle a zip, and send it to us manually via mail.
If you can send us the file you see this with, we could try to recreate. If it fails for us too, we can look into a fix. If it's small enough to attach you can send it directly to mail@resolume.com.
Generally, Resolume and Alley should be able to play what your OS can play natively. Windows movies and TV, and OSX quicklook would be the native viewers.
