careful with .xml files for prefs...
gpvillamil
Post by gpvillamil »
I noticed when saving my MIDI preferences that Resolume, by default, gives you the option to write the MIDI prefs .XML file over the general prefs .XML file.
It would be nice to have a bit of a safety net there... ie "are you sure you want to replace your prefs file with this other MIDI prefs file"
