Resolume and Decklink Intensity Shuttle conflict issues.
elbundlo
Post by elbundlo »
Has anyone had conflict issues using a Blackmagic Decklink Shuttle with Resolume? With Windows 10?
I have.
What is happening is this: Resolume seems to work fine until I plug in the Intensity shuttle (USB 3). Then all sorts of weird things start happening - the mouse freezes momentarily, the program appears unregistered for a while (I am using a dongle) and then it crashes.
The funny thing is that it seemed to work fine a couple of days ago.
I have just updated the driver for the intensity shuttle, but still no joy.
Any suggestions?
Re: Resolume and Decklink Intensity Shuttle conflict issues.
Yeah the driver seems to reset on it's own for me too, resets all the USB controllers.
Happens for me also without Resolume running, sometimes it works for a while sometimes not. No idea why.
Sometimes I see the shuttle in the Desktop video, but Media Express says it's not connected. Weird.
elbundlo
Post by elbundlo »
Yeah, it's like a USB conflict. I can see that in the Blackmagic desktop video setup, the Decklink loses connection momentarily. it keeps disappearing from the Sources menu in Resolume at the same time. I am also using a USB trackball mouse and I also lose control of that at the same time. I have just left Resolume on while I had my dinner, got back, and it was still running fine. Blackmagic video setup running too. It's as soon as you connect the two. One more thing - I kept on getting messages that the camera was turned on or off, so I disabled it in settings, didn't make any difference though...
An older BMD driver like 10.11.4 could help.
elbundlo
Post by elbundlo »
Solved!
The problem was a cheap USB dock. Doh!
Note to self: Always check for the most obvious thing before jumping to conclusions...
