How can I sync Resolume(PC) to the BPM of my Logic Pro mix(MAC)?
FreeTwitchBeats
I am attempting to sync the BPM from my Logic Pro mix on my Macbook Pro to Resolume on my PC so I can sync the visuals. Is this possible?
Re: How can I sync Resolume(PC) to the BPM of my Logic Pro mix(MAC)?
Resolume can sync BPM to Ableton Link, Midi clock signals.
You can also create midi shortcuts directly on the tempo controls: https://resolume.com/support/en/midi-shortcuts which would allow setting a specific tempo with a note or CC
FreeTwitchBeats
Thank you very much. I was able to successfully link it to Resolume
