ArtNet Sync
SimonSchmidt98
ArtNet Sync
Post by SimonSchmidt98 »
Hello Guys, I am new here.
I try to control RGB LEDs with Resolume, but my output is flickering. Is there an option to enable Artnet Sync to all DMX Outputs? I can’t find it.
Best Regards
Simon
Re: ArtNet Sync
Sounds like you have 2 things being sent to an output (conflicting packets).
SimonSchmidt98
Re: ArtNet Sync
No, it’s more like an desync while strobe effects.
I could solve the problem in any other software by enabling artnet sync, especially when I am using more than one controller.
Re: ArtNet Sync
Try lowering the output frame rate, some led controllers can't handle 40FPS.
https://resolume.com/support/en/dmx#framerate
Menno
Re: ArtNet Sync
Post by Menno »
Resolume does not currently support ArtNet VSync. We have issue #6938 for this in our features bucket, but it does not have a date scheduled to it. So for now your best choice is probably to route our output through a controller with syncing capabilities.
