Projection on 4 walls from 7 devices
rogalic
Post by rogalic »
I have to project on three walls and the floor with 7 projectors.
There will be two projections on the wall ahead, one on the left, one on the right and three on the floor. Everything is supposed to create one whole.
Will it be able to run with the resolume?
I understand that I will need a computer (what is the minimum configuration) and two Datapath FX4?
Thank you very much for your help.
Adam
vj8k3
Re: Projection on 4 walls from 7 devices
Post by vj8k3 »
im just commenting to bump. but I would think so
👮♟ ş𝕄𝕆ⓚᗴ ℂяⓐ℃k 卄AιĹ 𝓈ΔⓉ𝒶Ň 😎
Asus pro duo
Intell cor I7
16 gig ram
Gforce rtx 2060
mouse
He2neg
Post by He2neg »
~Berlin~
gpvillamil
Post by gpvillamil »
I found the Matrox QuadHead2Go pretty easy and bulletproof. Slightly more affordable than the Datapath.
In fact, you could possibly use 1 QuadHead2Go and 1 TripleHead2Go. If you go that route, the DisplayPort version of the TH2Go is far more reliable than any of the other versions.
