Upgrading and Installing New Version of Resolume
greenvillehughes
Post by greenvillehughes »
Sorry for this dumb question.
How do I upgrade and install Resolume 7.0 from 6.0?
Do I download the 7.0 version and run the setup program?
Does this overwrite the old version or can I keep running 6.0 in case there's a problem with 7.0?
Thanks for the help!
-Edwin
Re: Upgrading and Installing New Version of Resolume
V6 and 7 use separate app and documents folder, you can have them installed side by side.
Just use the v7 installer from the download page.
Then in the v7 Arena menu you'll find an Import compositions and presets function you can use to get your work into v7.
greenvillehughes
Thank You for the help!
