Hello, each layer has a slider for the Transition Time, this is great.
I have a group of 8 layers, and I would like to change the transition time for all layers at once.
Is there a way to do it?
Transition Time for Layer Group (Fading over time)
Desktop: Ryzen 9, 32GB Ram, Nvidia 2070S
4 x 4k Screens. One 4k monitor extra for Resolume Interface.
Laptop: Intel 7700, 32GB, Nvidea 1060, 2xNVME
Re: Transition Time for Layer Group (Fading over time)
Map them all to the same shortcut
Thank god I have an apc40, thanks that works.
I could map one knob to all of them.
I tried to map another knob to a single one of them, that however, didnt work.
Looks like Resolume elements do not want to be controlled from different Hardware knobs. at the same time. (reason I wanted is this, I wanted one for the whole group and one for only 1 layer individually)
you can do that. I map single parameters to multiple control surfaces all the time. Just right click the parameter you wish to double map and create new shortcut now you can have 2 things controlling it (obviously not at the same time, as in turning 2 encoders at once) but you can move one encoder, then move the next encoder and it will work just fine.
Right-Click! I didnt know that, awesome!
