No image when I use Indeo codec
beamlicious
Post by beamlicious »
I installed the driver allready>But I get nothing but a grey screen and preview.
I use 3D studio max and premiere, both programs wont work with Indeo.
What am I doing wrong ?
And what is a keyframe ??
beamlicious
Nobody ??
Please give me some help
continuity-B
Post by continuity-B »
You're not giving very much info
What do you mean 'won't work with indeo'? Do you get the option to encode .avi using indeo in these programs, or is it missing?
Try re-installing indeo also, but like i said it's not clear what your problem is
Google or search this forum on 'keyframe' if you want info on what it means - all you need to do is make sure is set every frame to be a keyframe if you use indeo (ie 'every 1 frame'). You should be asked this before exporting your movie in whatever program.
Do other codecs work (cinepac, MJPEG?) or other formats like .mov (quicktime)?
