How to ?
regieguimbarde
How to ?
Post by regieguimbarde »
We are working on resolume arena 6. we are making a project and we can't find a way to do it properly.
We are looking to dissociated the audio from a clip and send it to the 3 & 4 while all the rest of the project stay on the 1 & 2.
our question is : Do we need to control the audio with the clip or on the layer?
edit: we have a Behringer U-phoria UMLC 204 HD to work with/
pfelberg
Re: How to ?
Post by pfelberg »
Hello.
Your question is not very clear. If I understood it correctly, you want to play videos on layers 1 & 2, while audio files will be played using layers 3 & 4.
There's no difficulty to accomplish such a thing and I believe you would find your answers by reading the manual.
But, to answer your question, just place your content as you described in a single column, separated, targeting the respective layers. To play them all, just trigger the entire column by clicking on it.
You can control each playback by accessing the clip properties of the respective content.
Cheers
Paulo
Re: How to ?
Resolume (currently) only supports a stereo output for audio, so if you need more than a 2 channels of output audio this may not work.
