Akai APC40 MK1 - Shortcut Template
aeo
Post by aeo »
Hi! Just wondering if any APC40 MK1 users might have a MIDI shortcut template to share that I could use as a 'baseline' for setting my board up. I did find one here via the search function but it is for Arena 4 and I can't seem to get it to work with my install of Arena 6.
Thanks in advance!
Re: Akai APC40 MK1 - Shortcut Template
Pretty easy to set up a shortcut preset of your own: https://resolume.com/support/en/midi-shortcuts
The MK2 preset which comes with the installers, might also work.
