Bolt on shutter for projectors?
AcdNrg
Post by AcdNrg »
Folks,
is there such a thing as a shutter (DMX controlled) that one can put in front of a projector/beamer lens?
The idea is to black out the lamp, similar to what a shutter on scanners or moving heads does. Just displaying a black frame doesn´t do the trick, as the lamp remains visible.
Christoph
Re: Bolt on shutter for projectors?
Post by Christoph »
I always had good experience with Blackys:
https://www.theblacky.com/
(homepage seems to be in German though)
More professional projecors usually also have a built-in shutter that can be controlled via ethernet.
AcdNrg
Post by AcdNrg »
Thanks, will check them out.
mrmartinezbodega
Post by mrmartinezbodega »
There’s a device called a dowser that is made for this. It covers the lens without shutting off the projector and can be controlled via DMX.
