Issue with Cue Points (goes to black screen)
mikel_1985
Post by mikel_1985 »
Hi, I´m quite new using Resolume, so this could be some kind of misunderstanding by me or directly my fault, but I´m not being able to use correctly the cue points.
Once I set them in a clip, when triggering some of this cue points the output screen goes to black (also the little output monitor inside Resolume). Also, if I try to trigger some other clip to get out of that black screen, I will not be able to play any other clip correctly and just see it in my output screen.
Since I´m new with the software, it could be something I´m doing wrong, but any help to get out from here would be much appreciated.
I´m using Resolume Avenue 7.4.1
Thanks.
Re: Issue with Cue Points (goes to black screen)
Are you using midi to trigger the cue points?
If so, I'd guess you have a duplicate mapping to an opacity or layer bypass, which makes the composition or the layer go black.
Go tho the shortcut mapping and right click on the list, then sort by midi message to find the duplicates.
mikel_1985
Zoltán wrote: Mon Jul 05, 2021 08:50 Are you using midi to trigger the cue points?
Thanks a lot, it looks like that was exactly the problem.
