Wire - Fun with feedback errors
vjmandala
Post by vjmandala »
Hi, n00b here, am trying to replicate the 'Fun with feedback'.
https://resolume.com/support/en/wire-feedback-delay
I copy/paste web example patch into an ISF node and receive:
'Error, Could not create resource at <... all the pasted code>'
Any help be welcome. Chiz vjm
still pushin piXels...
Re: Wire - Fun with feedback errors
Try pasting it to the background of a new, empty patch, they are nodes, not ISF code.
Not being able to create the resource could mean Wire or your user is not allowed to write to the Documents/Resolume Wire folder.
Do you have a virus scanner installed which might prevent Wire from writing files, like the windows folder protection might?
vjmandala
Post by vjmandala »
Ahh ok. Thanks for feedback mate. Cheers, n00b :)
