Hey,
Is there any way to create your output transformation mapping from a set of imported points ? This way, I would be able to get an automatic mapping of complex shapes using camera/projector calibration and edge detection. If this is not possible, please let me know of any workaround you could think of.
Slices and mapping from cloud points
Re: Slices and mapping from cloud points
Not possible. But, I am working on something similar to this right now. Might be a month or two before anything comes of it. It won't use cameras, but input maps from shows as the source for the "auto mapper" to work.
Thanks for your answer.
Do you know if your work will be available somehow ?
Yeah, I'll post a link once it's done.
