Has anyone tested the midiman oxygen 8 already with resolume, do the twisting knobs work fine?
thanx bye
oxygen 8
MFx_
Yep, i've got one myself and didn't had any problems whit it when using it with resolume...the knobs are perfect !!!
If you're planning to use it with win XP, make sure you download the XP drivers, from the midiman website and install these, if you don't you can get some problems with shutting down the pc...
Good luck!
Good luck!
