another question. hopefully,i will get an answer to that one:
i tried to use the endlessknobs of the pocket dial in resolume, but i didn't manage to get it to work properly...
when using the 'fixed' setting in the midi preferences, the parameters jump to the value the MIDIcontroller is sending. so if one knob, (eg. for the opacity of the active layer) is set to 50% and i switch to another layer, then the parameter (opacity) of that new layer jumps to the old value (50%) instantly - not pretty.
when i use the 'endless' setting, there are no parameter jumps, but usually the range of the controller ends befor reaching the minimum/maximum value in resolume!
how can i configure endless knobs to work properly in resolume?
is there a way to do this without midifeedback of the software?
anyone using endless encoders here and can help?
thx in advance.
trm.
