Resolume not opening
adamwheatley
Post by adamwheatley »
I have just downloaded the trial of Resolume arena to test before rolling it out across our business, however I cannot get it to open on the trial PC. The splash screen loads but the software doesn't go any further and it says 'Error' on the tab on the task bar.
However it worked fine on an office PC.
I have attached the log from the PC with the problem and also the log from the working PC.
Any help/ advice would be greatly appreciated.
Resolume Avenue Logs.zip
Logs from working PC and non working.
(26.89 KiB) Downloaded 231 times
Re: Resolume not opening
The Radeon GPU you have is quite old, so might not work with Resolume. https://resolume.com/support/en/tech-specs
Try the latest AMD driver, maybe that helps.
