autopilot question
benoitvm
autopilot question
Post by benoitvm »
There is no way for the autopilot of one clip to trigger the next full column, only clips from the same layer, right ?
Thanks to confirm
Avenue 7.3.2
Re: autopilot question
Correct.
He2neg
Post by He2neg »
the workaround are dummy clips with the same length and set all layers autopilot the same way and trigger the next clips then together after you did start the first collom via the collom trigger.
or you need to use external solution for trigger all the stuff you want to be triggered
Free:
https://benjamin.kuperberg.fr/chataigne/en#home
or
http://palffyzoltan.hu/?url=controller&src=signature
or vezer (mac only ~120 $)
~Berlin~
