Resolume with 8k Canvas HELP
Colew1
Post by Colew1 »
Hello!
I have a canvas size of 7520X1280 on a PC with a Intel I9-11900k and 32gb of ram. Graphics card is a RTX 3080TI with a Black magic 8k Card.
I am having issues with videos freezing and layers taking longer to load. All content is in the DVX codec.
CPU usage is showing between 80%- 100% usage at all times with only 33%- 55% GPU usage.
Any ideas on how to get the CPU usage down to keep videos from lagging.
He2neg
Re: Resolume with 8k Canvas HELP
Post by He2neg »
More information are needed:
How many layers, how long are the clips....
what does it do with a clean comp (no clips loaded) after how many clips do it start to shutter
what is the advanced output (lot of mapping or not?)
do you have any other stuff running beside resolume...
do you have ndi inputs or outputs?
maybe when there are all needed information then someone can help and will respond ;)
~Berlin~
