Transform effect duplication
elgarf
Post by elgarf »
If I drag default transform effect from layer to clip (or from clip to layer), I get non-removable copy of this effect.
Re: Transform effect duplication
Hmm, yes indeed. The default transform is not meant to moved to other targets.
We'll see if we can prevent that.
Should not cause any issues though, you can either move it back or set it to default to have no effect.
elgarf
Post by elgarf »
Zoltán wrote: Thu Nov 25, 2021 20:52 Should not cause any issues though, you can either move it back or set it to default to have no effect.
Btw, I can undo this)
Sometimes effect duplicates, sometimes just moves. Not sure why.
