Wire freezes when i try to use Display 2
chaussette
Post by chaussette »
Hello, when i try to use Display 2 as an output, Wire freezes.
I'm using a Dell G7 7700 with a Samsung C27F390 Monitor.
Thanks in advance for your help :D
Re: Wire freezes when i try to use Display 2
Are you using a docking station for the external display?
chaussette
I don't think so, the monitor is just connected to my laptop by HDMI.
I found a "fix" by setting my monitor as display 1 and moving my Wire windows to the second display but the problem is not really fixed in the end.
Interesting.
Could you please send us the Wire log file via the feedback tab in preferences, once with the main display set to the built in, and then with it set to the external monitor?
chaussette
Nevermind ! I found Nahimic in my msconfig services (i had absolutely no idea it was on my computer), i deactivated it and now i can display on my second monitor :D
Thanks for your help anyway
