Clip Position XY Better control
pdubost
Post by pdubost »
Hello team,
I often have to add some quick elements and move them over my canvas
The natural straight way to do this for me is to play with the Clip Position Parameter,
It's too bad it doesn't have a slider like most of the parameters
An other way would be to use the Mouse Wheel to make the pixel value move
Anything that's more convenient than typing the value in number or clicking -/+
Thanks a lot
Phil
strangehead
Re: Clip Position XY Better control
Post by strangehead »
if you click and hold + or -, you can slide with the mouse
Online
You can also create keyboard shortcut, and holding that key, you can then move the mouse to adjust the params. https://resolume.com/support/en/keyboar ... mouse-mode
mrlupin
Post by mrlupin »
@Zoltan , I guess that the best solution would be a Gizmo on the viewport so we could move/ scale /rotate, set the pivot point . actually i love the one in Nomad sculpt
