I was wondering if you (anyone) recon this would be fast enough to run 2 seperate outputs from resolume at 720x576 , with out any effects. and if i am not having any effects, does the process resolution effect the output? if im showing footage recorded on a DV camera in resolume, outputed to a projector, should i deinterlace everything? will that effect the output resolution at all? efectivly dropping the resolution to 360x576, or should i keep the same ratio and half the width as well?
Is it possible to have only 2 outputs, one showing layer 1, and the other showing layer 2, and not have any interface at all. ive been testing on my computer with just a single output, and every time i make the output full screen it just shows a black screen, and when i trigger clips from the keyboard nothing shows up.
well i think these are the first noob questions ive asked in the year ive been on the forums
thanks, levon
