[solved] Arena buggy After new update 7.7.1
dstry
Post by dstry »
Hello,
after I updated to the latest release 7.7.1 is totally unreliable, the playback is jittery as hell and even if the clip is selected to start from beginning when selected, if I select the clip or the column, the clip always start from continue.
Even if I drag in the transport the head to the beginning of the video, jump to the last playing point...
The weird thing is that I even downgraded to 7.7.0 but the playback behaviour perstists.
Also the clip autopilot do not work on same project on PC, but works on Mac.
Can someone tell me what to do?
I have an installation in 2 days and I'm start to worry! :ugeek:
Thank you!
Re: Arena buggy After new update 7.7.1
Are you getting any input from another machine via OSC, for example?
Sounds like something tries to override the play position.
dstry
Post by dstry »
Hi Zoltán,
yes that was it, thanks! I always forget I quick is Resolume to sync with other machines
I still have issue with the clip autopilot, probably another settings, I will post it on another thread
thank you
