Resolution is rounding up/down
jwallis
Post by jwallis »
Is there a way to insert decimal places into resolume as a resolution? Our wall is 2400x1485 so it wont fit in a 1080p 16x9 box, so I had to squish it to 1744.8x1079.595
(which is 72.7% of the full resolution of the wall) then upscale it at the brompton. But resolume keeps trying to round it up to 1755x1080, is there a way to force it to take the exact resolution?
He2neg
Re: Resolution is rounding up/down
Post by He2neg »
You are talking about a LED Wall right?
Were are you trying to set this resolution? As Composition as Output or somewere in the advanced output settings?
If "real" output signal:
Are you sure your processor take this strange resolution?
Are you sure your machine can output custom resolution as well?
My normal approche is to fit the resolution of the wall inside the next bigger standart resolution accepted by the processor and place this at the right area so that everything fits...
when 2400x1484 is needed the higher resolution would be 4k, or use 2 times 1920x1080 and 2 led processors (but then you need to take care of sync and stuff)
~Berlin~
