Fonts not loading
Online
mowgli
Fonts not loading
Post by mowgli »
I am getting an issue whereby when opening a composition that uses text, some of the fonts used don't load. When looking at the font dropdown, the correct font is named but the font displayed is some default one. Re-selecting the correct font fixes the issue but this is just not practical as it involves going through every text clip.
Is there a fix to this?
Online
mowgli
Re: Fonts not loading
Post by mowgli »
The problem appears to be very random. It happens with certain fonts, some the default ones in Windows, others installed from Google fonts. It's also happening when triggering a clip, not just on opening the comp.
Opening the composition from the menu, or is it happening when Resolume loads the composition on startup?
Does a deck switch fix it?
Online
mowgli
Post by mowgli »
It happens if I change font and the undo. The font name changes but the correct font is not displayed.
Switching decks doesn't fix it.
I was just doing some tests and Resolume crashed. I've sent the crash report.
Found the crash report,
can you try the the latest nvidia studio drivers?
