[SOLVED] Python POST request
mungle
Post by mungle »
Hello,
I made a simple script with python to call some clips with a POST request.
Here my code:
Code: Select all
import requests
r = requests.post("http://192.168.0.11:8080/api/v1/composition/layers/1/clips/2/connect")
print(r.status_code, r.reason)
The print output is
204 No Content
but the clip n.2 is not connected.
If I use "select" instead of "connect" it works:
Code: Select all
http://192.168.0.11:8080/api/v1/composition/layers/1/clips/2/select
If I try with the API page it works (where I get the url).
Where's the problem? I'm using python over terminal on a Mac iOS. Thank you
ynohtna
Re: Python POST request
Post by ynohtna »
I think that endpoint requires the parameter true encoded in the POST body, supplied as the requests.post method call's data or json keyword parameters.
mungle
Post by mungle »
You were right!
Here a new working code snippet:
Code: Select all
import time
import requests
import json
richiesta = "http://127.0.0.1:8080/api/v1/composition/layers/1/clips/1/connect"
r = requests.post(richiesta, data=json.dumps(True))
print(r.status_code, r.reason, r.request.body)
time.sleep(.1)
r = requests.post(richiesta, data=json.dumps(False))
