Ignore clip when Autopilot is On
aaronrrc
Post by aaronrrc »
I always use autopilot mode, but I need some clips to be ignored, sometimes I need to play these clips, but only when I manually select them. What I do for now is to have another Decks, but as you know, when you switch decks you should wait Resolume to load it, and sometimes it takes a while for that. It would be very good to have an "Ignore Clip from Autopilot".... or maybe I'm missing something, is there another way to get what I want?
He2neg
Re: Ignore clip when Autopilot is On
Post by He2neg »
Autopilot can be set for each clip seperated:
you can chose the clip before to jump to the clip behind the "ignore clip"
maybe some work but its possible ;)
it would be faster to have 1 autopilot layer and 1 layer with the rest above it with the clips you dont want to play only with manuall selection
~Berlin~
aaronrrc
Post by aaronrrc »
Hey He2neg Thank you very much, you opened my mind, I was stuck with this!
