CARRYING CAPACITY OF AN ELECTRIC SKATEBOARD
devinfarrell
Post by devinfarrell »
Due to the advantages of electric skateboards over traditional means of transportation, especially when being used in big cities, many people have decided to own an electric skateboard. The majority of them use e-skates for daily commuting from their house to the office and backward.
However, before you can confidently ride an electric skateboard, you have to master all the skills and techniques. Since you intend to use an e-board as a new way of commuting, you have to consider the weight limit besides other factors when buying an electric skateboard.
>>>>> Related article: Electric Skateboard Weight Limit – How Much is Enough?
Without knowing the carrying capacity of the board, you can unintentionally create more stress for the structure of the e-board or even accidentally break it. The weight limit of a motorized skateboard depends on the power of the motor and the material used to manufacture the product.
If you want to understand more about the weight limit of electric skateboards, you have come to the right place. This post will not only explain the carrying capacity of an electric skateboard but also give you the reasons why it is an important factor to consider.
DOES THE WEIGHT LIMIT REALLY EXIST?
This is quite obvious but some skateboarders don’t think there's anything called the weight limit of an electric skateboard. To answer this question, I must say that each electric skateboard always comes with its own maximum carrying capacity. Therefore, people should check for these parameters when buying.
Without considering your body size and the weight limit of a motorized skateboard, you can snap the deck apart or experience an uncomfortable ride due to the unevenly distributed weight. The common structure of an electric skateboard has the battery implemented in the middle of the board; therefore, I don’t recommend you put both feet in the center of the deck or do any action that causes immense pressure on this point.
If you are a heavy rider, you should pay attention to your position while landing to ensure your feet are put over the bolts. This will ensure the safety of the board and avoid breaking it by accident.
THE AVERAGE WEIGHT LIMIT OF E-BOARDS
220 lbs are the most popular weight limit of electric skateboards on the market; however, if you are a bit taller or heavier than the rest, you may need to consider some products specially designed for heavy riders.
Based on what I know, there is a wide range of electric skateboards with the weight limit lying from 200 to 300 lbs. If you are not sure about the product, don’t hesitate to ask the seller for a better consultation.
SHOULD HEAVY SKATERS GIVE UP RIDING AN ELECTRIC SKATEBOARD?
There is a misconception that overweight people can not skateboard; however, unless you are too heavy, you will always find a suitable e-board for your body size. Although there exists a weight limit when you purchase an electric skateboard, it can usually withstand a higher weight than the number given by the manufacturers.
See more about weight limits when using electric skateboards at eSkatebuddy!
Of course, the performance of the board will be affected a little bit; however, this is the cost you have to pay in exchange for the riding experience on an e-skate. To protect yourself from common skating injuries such as ankle sprains, you should learn how to ride and land on an electric skateboard proficiently.
WHAT DECIDES THE WEIGHT LIMIT OF AN E-SKATE
As mentioned at the beginning of this post, the power of the motor is the first factor that affects the weight limit of a product. This is not just about safety but about performance. If too much weight is put on the board, the motor can not handle such a heavy ride and consequently, it can not accelerate and maintain the speed properly. Moreover, you had better not make the motor work in those overload conditions to maintain its quality.
The second factor comes from the material used in manufacturing an electric skateboard. The stronger the skateboard structure is, the more weight an e-board can carry. Therefore, remember to choose electric skateboards made out of good materials such as bamboo, Canadian maple, fiberglass, etc.
However, it doesn’t mean that a hardboard with a heavy structure can perform well for all skateboarders and all purposes. People who intend to do tricks on electric skateboards may not care much about the weight limit but about the flexibility and durability of the board because most e-boards can handle greater weight than the maximum.
>>> See also: electric skateboard max weight
WRAPPING UP
If you are too heavy for an electric skateboard, you should not be upset because these vehicles are just normal wooden boards attached to wheels powered by motors. However, you had better lose weight since it would be much easier for you to enjoy any sport and maintain your flexibility in sport. I hope that all skateboarders can find the perfect e-board based on their weight.
