Resolume 6 Crashing on opening composition
rahil8
Post by rahil8 »
So I’m on mac pro intel based 2019 model.
Using arena 6.1.5
Whenever I open certain compositions arena becomes un responsive & freezes. It says application not responding
Cannot check the log files since doesn’t get the crashing option/report, only since on those compositions hovering the mouse cause the crash then have to force quit.
Is it any particular file type that causes the issue ? If yes than what is the file type cause I’m unable to even probe for the file causing it.
Re: Resolume 6 Crashing on opening composition
Dropbox synced files which have not been synced to the disk can stall clip loading quite good till they get synced.
rahil8
Post by rahil8 »
Hey, thanks for the reply, what to do in such a case? Having major issues , don't have any dropbox files.
Try renaming the composition Resolume tries to load.
rahil8
Post by rahil8 »
Hi renaming also doesn't help, resolute opens fine but again loading the composition freezes the entire app. attaching the log file for your perusal.
Code: Select all
Resolume Arena 6.1.5 68469
Log started: 28 May 2022 11:31:44pm
INFO: Logging has started
INFO: Initialise JuceResapiApp
INFO: Initialise ResApi
INFO: Initializing Resapi
INFO:     Created ParamCollection
INFO:     Created TaskManager with 10 threads.
INFO:     Created InputController
INFO:     Created DeviceChangeDetector
INFO:     Creating VideoFormatManager
INFO:         Registering basic formats
INFO:         Registered 3 formats
INFO:     Created VideoFormatManager
INFO:     Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
INFO:     Creating NDIVideoServerManager
INFO:         Initializing NDI library
INFO:         Successfully initialized NDI library
INFO:     Created NDIVideoServerManager
INFO:     Creating DisplayCollection
INFO:     Created DisplayCollection
INFO:     ---Info main OpenGL renderer---
INFO:     Driver Vendor : ATI Technologies Inc.
INFO:     Renderer Name: AMD Radeon Pro 5300M OpenGL Engine
INFO:     Driver Version: 2.1 ATI-4.8.54
INFO:     OpenGL shader language version: 1.20
INFO:     -------------------------------
INFO:     Initializing renderer.
INFO:         Loading shaders...
INFO:         Successfully loaded shaders.
INFO:     Successfully initialized renderer.
INFO:     Initializing Resapi graphics
INFO:         Initializing GPUMonitor
INFO:         Successfully initialized GPUMonitor, using OSX strategy.
INFO:         Initializing TextureUploader
INFO:             Determining AutoDetect setting
INFO:                 AsyncUpload supported: true
INFO:                 Immutable Buffers supported: false
INFO:                 GPU Monitoring supported: true
INFO:             Autodetect would use inline transfers
INFO:         Successfully initialized TextureUploader
INFO:     Successfully initialized Resapi graphics.
INFO: Successfully initialized Resapi.
INFO: Install default PathParser
INFO: Enumerate fonts
INFO: Find default fonts
INFO: Create Application Object
INFO: Setting up default composition.
INFO: Resapi: setCurrentApplication
INFO: Init Colour scheme for user interface
INFO: Create LookAndFeel
INFO: Set LookAndFeel
INFO: Disable screen saver
INFO: Print version info
INFO: Major Version: 6
INFO: Minor Version: 1
INFO: Micro Version: 5
INFO: Revision: 68469
INFO: Id: 1
INFO: Revision string: rev68469
INFO: Version string with revision: 6.1.5 68469
INFO: Version string without revision: 6.1.5
INFO: Print application paths
INFO: Executable Path: /Applications/Resolume Arena 6
INFO: User Documents Path: /Users/rahilarora/Documents/Resolume Arena 6
INFO: Default Data Path: /Applications/Resolume Arena 6/default
INFO: Common Data Path: /Library/Application Support/Resolume Arena 6
INFO: Common Documents Path: /Users/Shared/Library/Application Support/Resolume Arena 6
INFO: Preferences Path: /Users/rahilarora/Documents/Resolume Arena 6/Preferences
INFO: Media Path: /Applications/Resolume Arena 6/media
INFO: Compositions Path: /Users/rahilarora/Documents/Resolume Arena 6/Compositions
INFO: Default Presets Path:
INFO: User Presets Path: /Users/rahilarora/Documents/Resolume Arena 6/Presets
INFO: Video Effects Presets Path: /Users/rahilarora/Documents/Resolume Arena 6/Presets/Video Effects
INFO: Audio Effects Presets Path: /Users/rahilarora/Documents/Resolume Arena 6/Presets/Audio Effects
INFO: Video Sources Presets Path: /Users/rahilarora/Documents/Resolume Arena 6/Presets/Sources
INFO: Audio Plugins Path: /Applications/Resolume Arena 6/plugins/afx
INFO: Video Plugins Path: /Applications/Resolume Arena 6/plugins/vfx
INFO: Previews Path: /Users/rahilarora/Library/Application Support/Resolume Arena 6/previews
INFO: Layout Presets Path: /Users/rahilarora/Documents/Resolume Arena 6/Presets/Interface
INFO: Print system info
INFO: Operating system: Mac OSX 10.16
INFO: OS 64 bit: Yes
INFO: CPU vendor: GenuineIntel
INFO: CPU speed: 2600MHz
INFO: Number of CPUs: 12
INFO: Memory size: 16384MB
INFO: System language is: en
INFO: Locate preferences directory
INFO: Locate settings file
INFO: Load Application settings
INFO: Install languages
INFO: Set fonts
INFO: Looking for unicode font
INFO: Unicode font found is: Arial Unicode MS
INFO: Language file font setting: FontToRenderThisLanguageInOSX
INFO: Language file font base height setting: 0.00
INFO: Create ApplicationController
INFO: Loading animation presets
INFO: Create AudioEngine
INFO: Load AudioEngine settings
INFO: Load SMPTE settings
INFO: Setup Effect presets directory
INFO: Setup Source presets directory
INFO: Creating VideoSourceManager
INFO: Created VideoSourceManager
INFO: Create VideoEngine
INFO: Load VideoEngine settings
INFO: Let VideoEngine scan for plugins
INFO: Scanning directory for plugins: /Applications/Resolume Arena 6/plugins/vfx
INFO: Scanning directory for plugins: /Users/rahilarora/Documents/Resolume Arena 6/Extra Effects
INFO: Loading plugins took: 0.04016 seconds
INFO: Set thumbnail for capture device sources
INFO: Initialize video engine
INFO: Register internal renderpasses
INFO: Initialize AudioEngine
Attempting to load VST: /Applications/Resolume Arena 6/plugins/afx/Resolume EQ-3.vst
Creating VST instance: Resolume EQ
Initialising VST: Resolume EQ (V1.0.0)
Attempting to load VST: /Applications/Resolume Arena 6/plugins/afx/Resolume Distortion.vst
Creating VST instance: Resolume Distortion
Initialising VST: Resolume Distortion (V1.0.0)
Attempting to load VST: /Applications/Resolume Arena 6/plugins/afx/Resolume Low-Pass.vst
Creating VST instance: Resolume Low-Pass
Initialising VST: Resolume Low-Pass (V1.0.0)
Attempting to load VST: /Applications/Resolume Arena 6/plugins/afx/Resolume Flanger.vst
Creating VST instance: Resolume Flanger
Initialising VST: Resolume Flanger (V1.0.0)
Attempting to load VST: /Applications/Resolume Arena 6/plugins/afx/Resolume High-Pass.vst
Creating VST instance: Resolume High-Pass
Initialising VST: Resolume High-Pass (V1.0.0)
Attempting to load VST: /Applications/Resolume Arena 6/plugins/afx/Resolume Bitcrusher.vst
Creating VST instance: Resolume Bitcrusher
Initialising VST: Resolume Bitcrusher (V1.0.0)
INFO: Create Composition
INFO: Register Composition with controllers
INFO: Create ShortcutManagers
INFO: Create ShortcutPresetManager
INFO: Create DmxController And Load Settings
INFO: Initializing ArtNet on adapter en0.
INFO: ArtNet initialization succeeded.
INFO: Set Fixtures Directory: /Users/rahilarora/Documents/Resolume Arena 6/Fixture Library
INFO: Register application specific renderpasses and sources
INFO: Load video effect presets
INFO: Load video source presets
INFO: Load audio effect presets
INFO: Create MainWindow
INFO: Create MainComponent
INFO: Install KeyListener
INFO: Install MouseListener
INFO: Create Monitor Panel
INFO: Create Layer Properties Panel
INFO: Create Clip Properties Panel
INFO: Create Composition Properties Panel
INFO: Create Toolbar Panel
INFO: Create Shortcuts Panel
INFO: Create File Browser Panel
INFO: Create Compositions Panel
INFO: Create Effects Panel
INFO: Create Sources Panel
INFO: Create Help Panel
INFO: Create Layer Group Panel
INFO: Create Slices Panel
INFO: Create UI manager
INFO: Set sparkle update accepted callback
INFO: Load auto-saved layout
INFO: Show main window
INFO: Create ScreenSetupDriver
INFO: Set ScreenSetup Presets Directory: /Users/rahilarora/Documents/Resolume Arena 6/Presets/Advanced Output
INFO: Load ScreenSetup Presets
INFO: Create AdvancedScreenSetupWindow
INFO: Set ScreenSetup Advanced Preferences file: /Users/rahilarora/Documents/Resolume Arena 6/Preferences/AdvancedOutput.xml
INFO: Enumerate displays and position MainWindow on primary device
INFO: Init Screen Setup
INFO: Attach screen setup inspector
INFO: Attach composition inspector
INFO: Attach menu to window
INFO: Create HelpController
INFO: Load HelpController file
INFO: Create OscController
INFO: OscController: Install Translation Strategy
INFO: Load OscController settings
INFO: Create MidiController
INFO: Refresh MidiController
INFO: Load MidiController settings
INFO: Start MidiController
INFO: Resapi Frame Cache
INFO: Create renderer
INFO: Start renderer
INFO: OpenGLCanvas: New context is created
INFO: Reading composition state took: 0.18914 seconds
INFO: Initialise took: 5.64668 seconds
INFO: Auto-saving layout
INFO: Serialize application model
INFO: Serialize video engine
INFO: Serialize audio engine
INFO: Serialize smpte settings
INFO: Create preferences file (config.xml)
INFO: Write preferences XML (config.xml)
INFO: Save animation presets
INFO: Save DMX preferences
INFO: Saving OSC preferences
INFO: Save MIDI preferences
INFO: Save Application Settings
INFO: Reading composition state took: 0.46162 seconds
INFO: Prepare for shutdown
INFO: Force Stop Recording
INFO: Composition Prepare for Shutdown
INFO: ***
INFO: Shutdown sequence started
INFO: Clear TouchBar
INFO: Auto-save layout
INFO: Clear menu delegates
INFO: Detach Composition Inspector
INFO: Composition Shutdown
INFO: Stop renderer
INFO: Stop Server if running
INFO: Clean up renderer
INFO: Save Application and VideoEngine settings
INFO: Clean up UI
INFO: Context will be deleted: monitor
INFO: Save Video Effect Presets
INFO: Save Source Presets
INFO: Save Screen Setup Simple Settings
INFO: Save shortcuts and presets
INFO: Stop output shortcut managers
INFO: Clean up LookAndFeel
INFO: Clean up HelpController
INFO: Clean up DmxController
INFO: Clean up OscController
INFO: Clean up MIDIController
INFO: Clean up Compositon
INFO: Destroying ClipController
INFO: Done destroying ClipController
INFO: Deinitialize AudioEngine
INFO: Clean up Audio Engine
INFO: Clean up Video Engine
INFO: Clean up RecordingController
INFO: Clean up ApplicationController
INFO: Clean up FixtureSelection
INFO: Clean the UI Factory
INFO: Clean up Application Object
INFO: Shutdown JuceResapiApp
INFO: Release ResApi
INFO: Shutdown ResApi
INFO: Deleting myself
This looks like a clean exit.
Can you share your composition so we can take a look?
