If there is already a way of achieving this please advise.
Edit: I see one pan across the patch when zoomed in. From https://resolume.com/support/en/wire-user-interface
Not a high priority, but would also be good to have a mini "birds eye" view of a zoomed in patch, showing the zoomed in area within the entire patch extent. Ideally one could then slide a small window of the zoomed in area across the representation of the patch extent.The patch screen can be traversed by holding down the spacebar and click-dragging across the screen. The cursor will change into a hand, indicating that you are ready to pan. Alternatively you can press and hold the middle mouse button to pan.
