TIP: Mac: Wire vs Arena/Avenue integration: Set access to Documents to ensure see Wire patches
webel
Post by webel »
Mac tip:
If your Arena/Avenue does not see your Wire patches (Sources, Effects, Mixers) make sure that Arena/Avenue has access to the Documents folder, because the Resolume Wire Patches folder is by default under Documents. Use Systems Preferences > Security & Privacy > Privacy > Files & Folders and make sure the Documents Folder checkbox is selected for Arena/Avenue under the apps list.
Darren Kelly (PLAYlogo), Webel IT Australia
