Media serwer for 3 MCTRL 4K
AdamDGK
Post by AdamDGK »
Hi, I am asking you for help in choosing the equipment.
The job to do is 3x4k MCTRL 4K on one wall. Resolume works well with amd? I thought about:
Ryzen 7 5800X
Asus PRO WS X570-ACE
Quadro RTX A4000
QUADRO SYNC II
Blackmagic Mini Converter Sync Generator
BlackMagic Design DeckLink 8K Pro
What do you think about it?
Cheers;)
Re: Media serwer for 3 MCTRL 4K
Quadro sync is for multiple Quadro cards. If you only have 1, you don't need it.
BMD is notorious for cutting corners and just not working unless it's a specific driver revision that is unknown to everyone. AJA Corvid would be my SDI PCIe card of choice.
You could also use any old gaming laptop with a single 8K output into Novastar's 8K to (4) sync'd 4K output box (Think of an 8K FX4).
AdamDGK
Post by AdamDGK »
We have a lot of problems with AJA in Europe. BM gives a lot for a low price. I prefer magewell. It turns out a4000 without a sync card solves my problem. true?
It would sound like it. Yeah, use whatever has been successful for you in the past :) I was just adding my experience with BMD to the mix.
isprod.se
Post by isprod.se »
I run x299 with resolume, i have 3 bmd quad 2, never failed ever. Must keep card up to date with fw ;-)
Latest software updates usually kills most of my BMD hardware ;)
