This is maybe something for the guys with the more messy compositions.
Maybe someone of you know the Problem.
The time will come while a party and you already triggering clips for 8 hours.
Layer 1 -> Plays Clip in Deck 2
Layer 2 -> Plays Clip in Deck 1
Layer 3 -> Plays Clip in Deck 5
Layer 4 -> Plays Clip in "Cant remember the Deck"
GUI -> Deck 3 is open with nothing triggered in it.
In the Layer we can see which clip is triggered, but not where the clip is located.
Think it would be a nice option to make a right click on the thumbnail in the beginning of the layer and getting the option: "Jump to clip location"
Maybe there is an option an I havent found it until know.
Jump to deck where current clip is played
Re: Jump to deck where current clip is played
Not sure if this would be the same thing, But I think it would be nice to temporarily toggle the Persistent tag on clips when they are active and you move to a different deck, this way if you need to see it in your clip window, you can have access to it there. If you are just wanting to change the clip properties, you should be able to click on the clips name while it's connected to it's layer.
I find myself quite often in a similar situation, when all I need is to be able to jump to the deck where a specific active clip lives, that could be for different reasons like to duplicate that same clip to another layer.
