RX 580 FPS problem
DaneDavies98
RX 580 FPS problem
Post by DaneDavies98 »
Hey there,
Running 7.9.0 , and have 2 x AMD RX 580s in the PC, running 3 outputs at 1080 each. At one input the playback is 60FPS, by the 3rd output we are hitting 16-20 FPS. The GPU is running at 20% max, and nothing is throttling. Any recommendations on a fix for this issue?
Re: RX 580 FPS problem
Activating outputs will always come with a performance hit, especially if the output is on a different GPU.
http://resolume.com/forum/viewtopic.php?f=7&t=15035 has some pointers on options to send to lots of displays.
