Touchdesigner into Resolume
elbundlo
Post by elbundlo »
Hi folks,
Does anyone have any tips for getting more than one source from Touchdesigner into Resolume?
I have been experimenting recently with some degree of success, but it is a bit hit and miss: sometimes Resolume sees both sources, sometimes it only sees one source and often the source 'freezes' - just a still image.
I should add to this that my sources in TD are audio reactive.
Any suggestions?
Thank you for reading.
Paddy
Re: Touchdesigner into Resolume
How are you sending? I use spout and I can send several senders this way.
elbundlo
Post by elbundlo »
I am sending via syphon/spout out.
Seems to be working fine for me. I would check your spout settings to see if you have a cap/limit set to senders.
elbundlo
Post by elbundlo »
Thanks mate,
I think I was probably expecting too much from Resolume because I was mixing footage and other sources as well as having touchdesigner as a source. As long as I am only using only touchdesigner, it works fine.
