Request: Shortcut Resize Fit
timvangucht
Post by timvangucht »
Hello,
I think it would be useful to have a shortcut resize fit.
It would also be nice if you could do that for all decks at once.
In my example, for a DJ I have for each song a deck with visuals, but my composition resolution varies per show and I want to quickly resize visuals.
Re: Request: Shortcut Resize Fit
This has been a feature for as long as I can remember.
https://resolume.com/training
https://resolume.com/support
Be sure to take advantage of all the training videos and support documentation available to you. A lot of time and hard work went into those :)
You can do this under the Video tab under each layer or group or each clip has a 2 way diagonal arrow at the top right of the green header bar of the clip under the clip properties. Pick your poison ;)
Also Check the Layer's Auto size option.
metafred
Post by metafred »
sooo.. what's the shortcut for fit?
it used to be F, but not anymore
You can Keyboard map the letter "F" to this button and set it to "Selected Clip" to have an auto resize button.
