Alley: Does not recognise HEVC file with .m4v suffix (add .mov)
webel
Post by webel »
Alley: 7.10.0
Mac
Alley will not load HEVC exports (from Compressor) with .m4v suffix.
Adding (or changing suffix to) .mov works.
Darren Kelly (PLAYlogo), Webel IT Australia
Re: Alley: Does not recognise HEVC file with .m4v suffix (add .mov)
Does quicklook play that m4v?
webel
Post by webel »
@Zoltán
If you mean the mini preview in the optional preview side pane of the Finder, yes.
And QuickTime 10.5 plays it fine.
Alley just seems to ignore it if only has .m4v suffix, it won't appear in the View pane.
Could you share a short sample file we could check out?
webel
Post by webel »
Please see email with same title for link.
Thanks, got it!
