Wire: 7.10.0: Disconnects Dither when change gradient type
webel
Post by webel »
Might be intentional, but worth noting.
If you have a Gradient with an Int to the Dither inlet and change the Gradient type - between vertical horizontal, radial, angular - the Dither inlet disconnects. Not so easy to notice at first, easy to miss and not re-connect.
Darren Kelly (PLAYlogo), Webel IT Australia
Re: Wire: 7.10.0: Disconnects Dither when change gradient type
Thanks for letting us know!
Made a ticket.
